It is currently Mon Aug 24, 2026 12:07 am
 Post subject: Finger board
PostPosted: Sat Aug 22, 2026 2:05 pm
Finger board or low telco?
Should I remove the removable ICs?
Have a bunch of them
 Post subject: Re: Finger board
PostPosted: Sat Aug 22, 2026 2:17 pm
The debate should really be high telco or GFC.
I'm borderline on the population being enough for high telco but leaning yes. You'll need to remove the bracket for that.
PostPosted: Sat Aug 22, 2026 2:58 pm
I think those dip switch packs are the kind with gold balls. If so that should help push it over the edge if marked had not calculated that into his reply.
PostPosted: Sat Aug 22, 2026 4:05 pm
Good call - busted one open to confirm
PostPosted: Sat Aug 22, 2026 5:25 pm
I did to a degree but hesitated to mention it lest they get ripped off. xD
Pull the bracket throw it in high Telco
PostPosted: Sat Aug 22, 2026 5:49 pm
One switch out of fifteen on the board, it’ll be fiiiiiiine
PostPosted: Sun Aug 23, 2026 3:39 pm
Nice! You got the gold bearing dip switches. NOT ALL DIP SWITCHES ARE.
How about that connector on the end? Gold pins?
Yeah. Remove the bracket. Junk metal a no no.
Don't remove any ICs.
Are those yellow tear drops tants?
Having said what I said.
I agree with Marked141.
High Telecom.
