It is currently Sun Oct 25, 2026 11:35 am
 Post subject: To cut or not to cut
PostPosted: Thu Aug 27, 2026 3:18 pm
Hello,
I have a bunch of these boards with metal plating that is very difficult to get off. There isn't a lot underneath the plate. Am I better off cutting the board as pictured and just sending the top portion in as peripheral or will I get docked sending the whole board in?
Thanks!
Robb
 Post subject: Re: To cut or not to cut
PostPosted: Thu Aug 27, 2026 5:45 pm
The plate on drops to midgrade.
PostPosted: Fri Aug 28, 2026 8:54 am
Thanks! I'll start cutting. Most of the metal covers on RF equipment are easy to pop off, these seem to be bonded with some alien technology glue...
PostPosted: Fri Aug 28, 2026 1:40 pm
I could be wrong but I though I recognised that board layout as a network interface card… but the connectors are missing. How do you plug it in?
PostPosted: Sat Aug 29, 2026 9:46 pm
These are external network units of some sort that were in plastic housings. Based on the external housing conditions (dirty) they are set up outside. They only have the (2) ethernet ports. I also get barrels fully of external cat 6 cables from this company, which I assume was used with these. The company provides over-the-air internet service.
PostPosted: Sat Aug 29, 2026 10:13 pm
Ah, amplifying bridges of sorts.
