It is currently Fri Sep 04, 2026 2:37 am
PostPosted: Wed Sep 02, 2026 9:00 pm
I rarely get anything other than pc's and laptops. so, some of these boards are a battle.
PostPosted: Wed Sep 02, 2026 9:14 pm
1(?) I don't know how to advise on the mercury relay board at this point. Lost would have a better handle on that.
2. High peripheral
3(?) I would lean toward i-series unless someone else is more familiar with this board. Do remove the heatsink plate from underneath. The CPU bracket should be separate and can stay.
PostPosted: Thu Sep 03, 2026 10:41 am
The guys at wickliffe told me they will take mercury cards
PostPosted: Thu Sep 03, 2026 11:37 am
If Boardsort wants to put out a statement regarding mercury relays that is different than what was discussed here, I'll gladly adapt to their policy. Otherwise I'm sticking with Lostinlodos' advice regarding removal:
lostinlodos wrote:
For dip (IC) style, only ones in sockets. Otherwise the board is hazmat.
For canister style if you have enough experience to make clean breaks in a PCB you cou punch a hole around it and remove the can from the board. But generally best to hazmat the whole board.
For tube style they usually have a quarter or half turn socket. Push down gently and try to turn it. Some are clockwise some counter-c.
Mercury is a neurotoxin. Impossible to clean up in quantity without experience, and causes toxic stains in organics and cloth. If you aren’t 100 percent sure you can remove it safely don’t try.
PostPosted: Thu Sep 03, 2026 1:24 pm
I looked at the back of the board
The relay had 4 pins so I popped it off nice and clean.
My local solid waste agency accepts them.
