It is currently Tue Sep 08, 2026 10:59 am
 Post subject: Help Grade These Boards
PostPosted: Sun Sep 06, 2026 5:03 pm
The boards shown have all been pulled out of a LCD/LED TV, I want to get a grade on each of them. I’m new to the e-scrapping world and am trying to learn as much as I can, you’re help will be much appreciated.
PostPosted: Mon Sep 07, 2026 8:43 am
Board 1 probably HGP if you take off the heat sink. I think 2 and 4 might be high grade.
Otherwise all mid grade besides 3 which is low grade
Edit: also forgot to mention board 5 is HGP
PostPosted: Mon Sep 07, 2026 1:03 pm
Just a few additional comments.
Board 2. Remove shielding. Helps grade.
Board 3. I would remove the fuse.
Board 5. Remove those fragments of orange flex circuit. Also. Always remove any possible glass fragments.
Board 8. Remove shielding. Could be good stuff (chips) under shielding. Helping grade.
As a general comment overall. And it is brought out in videos. Remove junk. Heatsinks. Brackets. Shielding. Metal standoffs. Just plain metal junk affects grade value.
