It is currently Tue Sep 15, 2026 10:39 pm
PostPosted: Wed Sep 09, 2026 3:28 pm
These boards are from flat screen TV's, I removed most the "junk" from them, would they qualify for high grade? The backs don't have any components.
Thanks
PostPosted: Wed Sep 09, 2026 5:06 pm
All Low Peripheral. You have a lot PCB with nothing note worthy on them.
PostPosted: Wed Sep 09, 2026 7:07 pm
I see potential gold pins and 5-7 ICs apiece at least. I'd lean toward high, especially if there are gold pins.
The middle board does still have a cable box/shield (may be difficult to remove) that wouldn't hurt to remove if you can.
PostPosted: Wed Sep 09, 2026 9:21 pm
Thanks for the info Marked141, I had always thought (according to the video Chris posted) almost all mother (main) and t-con boards from LED TV's were high peripheral grade, and have also watched some vids from Sharkscraper and he has said he generally is able to put them in with high grade but wanted to confirm this if possible before shipping them. Again, thanks for the help.
PostPosted: Wed Sep 09, 2026 11:55 pm
Well. Marked141. You are right. I mistakenly did such a fast look at those boards and did not see the small IC packages.
I thought to add this comment. To be considered an IC. The component must have minimum 6 legs.(pin outs). Those are real small die packages. Obviously why I missed them.
I was wondering if any forum member can make a comment on sizes of IC packages to e-scrap value. Now. I do know this. A large package is used many times just for the sake of heat distribution. Foregoing the need for heat sink. Etc. Yet. Still containing a small die chip. But in a big plastic package. Even so. I would like to hear any comments about e-scrap value relating to IC package size. One would naturally think. The bigger the more value.
