It is currently Sun Sep 20, 2026 6:35 pm
 Post subject: IC Chip Varieties
PostPosted: Thu Jan 05, 2023 3:30 pm
I've been having a little trouble finding info on IC chips in the forums.
The price list has entries for plain IC Chips ($8) and Gold Cap and Leg 8086 ($175), but I've found a few variations that seem like they may fall somewhere in between.
Just in these photos we've got:
-gold cap+leg
-gold cap+leg PLUS gold underside
-plastic with gold leg
-gold leg with a little octopus on top
-gold cap + silver leg
-silver leg ceramic
no idea what #11 is
Any insights on where these oddballs fall in the scheme of things?
 Post subject: Re: IC Chip Varieties
PostPosted: Mon Sep 14, 2026 3:53 am
#1 I would submit as Connector Ends.
#2,3,7,8 Gold Cap Gold Leg Ceramic
#5,9 Gold Cap NO Gold Leg Ceramic IC
#4,6 Plastic IC chip with Gold Legs
#10 DIP Resistor Pack. It is not an IC
#11 It uses BGA connection. But. Unsure if it is an IC. Need to see part number.
PostPosted: Mon Sep 14, 2026 2:15 pm
Think I concur with our whiskered friend, note...
1, with the component soldered on it might impact things ¯\_(ツ)_/¯
5,9 should say gold cap no gold legs
11, likely a flat pack or BGA no gold tab
PostPosted: Mon Sep 14, 2026 3:03 pm
Thanks. I edited my mistake.
#11 Most likely BGA. No gold tab. I was hoping to see the part number. Or. Even better. Cut that metal off. And lets see if a die is in there. Just a curious.
PostPosted: Sat Sep 19, 2026 2:09 am
1. Those older style Oscillators with the gold legs or caps sometimes are labeled an IC with what function it has. My assumption with the soldered on dual-line.
Possibility as plastic IC gold leg, question mark?
10. I would assume that's still an IC. Certain DIP and SIP are still considered ICs. Most have a die with valuable circuitry.
PostPosted: Sun Sep 20, 2026 2:17 pm
Oscillators always seem to sit in that awkward middle bin, especially once solder is still hanging off them. #10 having a die makes the label debate feel a bit less cut and dry.
PostPosted: Sun Sep 20, 2026 3:16 pm
Look up the part number #10. It is a DIP Resistor Array. No die chip. Made by CTS. Just a compound on a ceramic base.
When Boardsort is buying resistor arrays similiar to what is posted as IC chips. Let me know. I got quite a few. Still in the original packing. They are not a iC chips.
I stand down. On being corrected.
