It is currently Fri Oct 02, 2026 7:46 pm
 Post subject: Board identification
PostPosted: Tue Sep 22, 2026 6:47 pm
What does it mean at the bottom of your post if is shows locked? Did I do something wrong.
It was only for a board identification. Thanks for any help.
 Post subject: Re: Board identification
PostPosted: Tue Sep 22, 2026 7:11 pm
Were you signed in?
Every now and then the site logs me out for no apparent reason and I sometimes get weird red warning text
PostPosted: Tue Sep 22, 2026 7:13 pm
Oh! I see, you're right that is locked
Well...for what it's worth I was hoping someone else might chime in, it's an interesting board. Had characteristics of a motherboard but isn't a layout I recognize to be able to call it a motherboard for grading purposes (it may in fact go into a mobo grade).
I would pull the aluminum heatsink at least, then maybe high peripheral on the grade.
¯\_(ツ)_/¯
PostPosted: Tue Sep 22, 2026 7:16 pm
Not sure if it was something I did. Maybe an answer will appear tomorrow.
Thanks for the reply.
PostPosted: Tue Sep 22, 2026 7:19 pm
Lostinlodos! If you see this, it's this post:
viewtopic.php?f=12&t=25612&p=57236#p57236
Let us know what's up.
PostPosted: Wed Sep 23, 2026 5:29 am
Thanks for all your input. It goes in a processor for traffic intersection
monitoring. Do you think the copper coils need to be removed also.
PostPosted: Wed Sep 23, 2026 9:18 am
They should be fine for high peripheral. The aluminum might even be fine as small as it looks but it's hiding the chip under it.
PostPosted: Tue Sep 29, 2026 11:19 am
Be careful with small, flat aluminum heatsinks. I pulled one off and it took the chip off with it.
Newbie. Have not yet sold anything to boardsort. Was previously getting shred prices from a local yard.
Northeast Ohio area now, formerly of Terrebonne Parish, LA.
PostPosted: Fri Oct 02, 2026 1:38 pm
Those little heatsinks can be glued on way harder than they look. Not worth turning a decent board into loose scrap over a tiny bit of aluminum.
PostPosted: Fri Oct 02, 2026 3:28 pm
That one has spring loaded plastic pins, shouldn't be an issue to push the tops down and cut the wider bit on the reverse side of the board; you could do that to the top but remember there's a spring there to cut through too. Should pop right off.
