It is currently Sat Oct 03, 2026 10:05 pm
 Post subject: Board inquiry
PostPosted: Fri Oct 02, 2026 1:28 pm
Will copper coils on a board bring a periphileral high grade board down to low
grade. I am waiting on a reply from the FRED inquiry. If so I have boards I need to modify.
Thanks
 Post subject: Re: Board inquiry
PostPosted: Sat Oct 03, 2026 12:03 pm
Junk on a board will affect grade. It is a matter of degree. That is where watching the e-scrap videos help you learn to determine what and how much to remove. The forum helps tremendously. Getting information from seasoned e-scrappers is priceless. But. The final determination is Boardsort.
When posting boards. It is important to see the front and back photos. I would like to see the opposite side of the board you have just posted.
For what I see at the present. That will go High Peripheral even with the coil on.
Also. Board identification should be posted in the What it is? Area.
My evaluationns are my own opinion.
PostPosted: Sat Oct 03, 2026 5:02 pm
It was graded low periphileral by Boardsort with the 2 coils It had 1on each side.
I resubmitted with them removed and they graded it high periphileral so I am removing them.
Thanks for your insight.
PostPosted: Sat Oct 03, 2026 5:08 pm
Those metal studs you left in are a part of the junk problem also.
What did F.R.E.D. come up with?
PostPosted: Sat Oct 03, 2026 7:53 pm
You give Fred both sides of the board?
PostPosted: Sat Oct 03, 2026 8:14 pm
Yes. You can give F.R.E.D. both sides. But. It is not a requirement.
PostPosted: Sat Oct 03, 2026 8:22 pm
I watched the High Peripheral video from Boardsort.
I then watched the Peripheral Board video on You-tube by the Shark Scrapper.
I still think the board pictured here has a strong case for High Peripheral even with the "coil" pictured. Which is really a relay.
I am bumfazzled.
