It is currently Tue Oct 06, 2026 9:27 pm
PostPosted: Tue Oct 06, 2026 1:17 pm
As the pictured board is. Not cleaned.
What would it grade as?
Also. If I cut the board at the black line I drew on it. Would it be a good idea?
If you look. You will see a dotted line put on by the manufacturer. Labeling one side hot. The other cold. Basically where I drew my line. Also. Seemily separating a Mid Grade section from a High Peripheral section. If you can see what I mean.
OR! Should I just clean the transformers off. Remove the large capacitor. Also all the small coils.(labeled L). What would it go as then? If it grades as High Peripheral. That's the best choice. In my opinion.
Looking for input. A real e-scrapping question. Especially if one has a large number of boards.
It's complicated.
