Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 17 posts ]  Go to page Previous  1, 2
PostPosted: Fri Jan 01, 2016 3:25 pm
Usb charger and cable (Samsung)
File comment: Unit... top off
File comment: Plastic
File comment: Gold connectors
File comment: I'm going to place this as a gold wire connector until I hear from Chris
File comment: #1 copper wire
File comment: Silver plated brass
PostPosted: Fri Jan 01, 2016 4:52 pm
At&t router
File comment: Outside
File comment: Inside
File comment: 400 stainless
File comment: Steel
File comment: Peripheral main board
PostPosted: Fri Jan 01, 2016 5:08 pm
Zenith analogue cable tuner
Look at photo notes for details
File comment: Box
File comment: 8 or 8.5 security torx
File comment: Watch out. Big nicad battery
File comment: Big main board
File comment: Pry them open for 400 stainless lids, #1 yellow brass shields and midgrade boards
File comment: Silvet connectors
File comment: Steel
File comment: #1 yellow brass
File comment: Midgrade for boardsort. Probably cbm #1 or #2
File comment: Peripheral. Large bump ICs on back
File comment: Lock. Brass #2 or iron/brass motors
File comment: Hard tough ferromagnetic material. It's not steel (no nickel or iron) not sure what it is. (Steel shred bin)
File comment: Normally brown/tan goes mid or low. This has good ic population and many silver connectors plus gold contacts. Peripheral
File comment: Sheet aluminium
PostPosted: Fri Jan 01, 2016 5:10 pm
Ti nspire projector
File comment: Get the screw under the aluminium laminate
File comment: Gold recovery
File comment: #2 wire
File comment: Aluminium laminate
File comment: #1 nickel
File comment: Silver plug
File comment: Cbm #3
File comment: Cbm #2
PostPosted: Fri Jan 01, 2016 5:12 pm
Power brick.
This from a ti nspire
File comment: Brick
File comment: 2 screws and pop
File comment: Low grade
PostPosted: Fri Jan 01, 2016 5:28 pm
Dtv satellite dvr
File comment: #1 wire
File comment: Silver connectors
File comment: Silver flat ends (go with silver ram)
File comment: Silver fuse
File comment: Get these little screws; they mess up recycling.
File comment: Steel
File comment: Fan motor
File comment: 325 stainless
File comment: Gold recovery from sim
PostPosted: Thu Nov 17, 2016 5:42 pm
Minor updates
