It is currently Sat Nov 07, 2026 12:19 pm
 Post subject: Connector ends
PostPosted: Fri Oct 16, 2026 12:02 pm
Hi I’m looking for some help, i was wondering if these communication harness connectors are gold plated pins would they classify as connector ends?
Thanks in advance
Anthony
 Post subject: Re: Connector ends
PostPosted: Fri Oct 16, 2026 12:15 pm
Looks like the pins are gold plated.
Yes. Cut the wire off.
Submit the rest as Connector Ends.
PostPosted: Fri Oct 16, 2026 7:01 pm
The plastic cover on the back tends to be fairly easy to remove. Then you can pop that off and cut the wire closer to the connector end.
PostPosted: Fri Oct 16, 2026 7:22 pm
Marked141. Am I missing something?
If you look at the Connector Ends video in the E-scrap price list. What you suggested is unnecessary.
Is there a better price for cleaning beyond what is in the video?
PostPosted: Sat Oct 17, 2026 10:00 am
**** Is there a better price for cleaning beyond what is in the video*****
No , but 2 thoughts/opinions
1. Boardsort’s prices are based on a rolling formula of their profit margin from the category, so if all of us send connector ends with a little extra/unnecessary junk, their profit goes down so they lower what they pay us for them. Vice-versa if their profit margin goes up.
2. For shipping purposes, the more you get in a box the more profit, so the smaller the items the more items. So If it only takes 5 seconds to pop off while you already have it in your hand, why not increase your personal profit and Boardsort’s and help keep prices up for all the scrappers.
PostPosted: Sat Oct 17, 2026 12:05 pm
In response to bw489822.
#1 point. Overall as a collective group. E-scrappers won't voluntarily participate in cleaning connector ends without some type of up front incentive put before them. For example. Cleaned Connector Ends vs Uncleaned Connector Ends.
Yes. The dynamics are there of better prices for cleaning. But. The results are not established. As a category on the price list. Result. They would clean for the "pie in the sky" category.
#2 point. I do concern myself with what you said. I mail in exclusively. I consider shipping weight and volume taken up in a package. I will clean when it makes sense.
I would say a clean weight versus unclean weight affecting mailing rate study is called for. But connector ends are so randomn and inconsistent. I guess just " fly by your pants" whether you clean or not.
Good points bw489822.
PostPosted: Sun Oct 18, 2026 3:42 pm
You're cutting the wire anyway, so it comes down to, do you have a buyer offering more for the wire than BS for connector ends after processing/handling and shipping/driving.
Depends on individual's situation.
I almost suggested yanking the wire out once the cover is off to pull the pins out. Then you can trim all those off for gold plated pins... which is just another step along the way of "is it worth my time"
Depending on Op's setup maybe they can cut right through that plastic cover and recover most of the wire anyway (which would be awesome) and render this all moot.
¯\_ (ツ)_/¯
