It is currently Mon Nov 09, 2026 12:11 pm
 Post subject: M- card. I.D.
PostPosted: Fri Nov 06, 2026 6:09 am
Found an M-card. Removed metal.
Had to remove a battery.
Opinions on grade.
 Post subject: Re: M- card. I.D.
PostPosted: Fri Nov 06, 2026 8:56 pm
Unsure how significant the gold is. High peripheral at minimum.
PostPosted: Sat Nov 07, 2026 11:23 am
Cut back plastic with razor knife.
Nice gold contacts.
Inquiry minds who want to know.
PostPosted: Sat Nov 07, 2026 3:14 pm
I'm just unsure if the tracings are significant or not to boost the grade
PostPosted: Sun Nov 08, 2026 3:59 pm
Chris told me all the flash cards and the like that I had were high telecom once I stripped the cases off them
PostPosted: Sun Nov 08, 2026 6:17 pm
The IC population is the main thing holding me back from saying high telco immediately.
PostPosted: Mon Nov 09, 2026 9:08 am
Instead of number of ic, consider the percentage of surface area the 3 of them inhabit along with all the visible gold. I always send similar stuff as high telco and haven’t had any issues
PostPosted: Mon Nov 09, 2026 11:34 am
That is what I meant ¯\_ (ツ)_/¯
I'm trying to avoid the assumption that every card like these will always be high Telco, cause I don't want our whiskered friend to dump every laptop pcie card into a bucket and expect Telco; normally the lowest grade is high peripheral but I'm sure there's worse ones too. I don't disagree that this card has a good chance getting top price. If there were more ICs it would assuage my uncertainty with the gold. If I knew the visible gold was a good plating and not flashed it would assuage my uncertainty with the ICs.
