It is currently Sat Nov 07, 2026 3:59 pm
 Post subject: E scrap 2016
PostPosted: Thu Feb 04, 2016 8:45 pm
Power supply?
 Post subject: Re: E scrap 2016
PostPosted: Fri Feb 05, 2016 3:14 pm
Boardsort has a flat rate for powersupplies. Regardless of format.
You may have stainless steel or aluminium casing though. Use a magnet. If it doesn't stick you're better off breaking it down. Both aluminium and 300 series stainless are worth considerably more than power supply rates.
PostPosted: Fri Feb 05, 2016 8:58 pm
I have alot..
From old server
Units and ect.....
Some very big
Some small.
PostPosted: Sat Feb 06, 2016 12:11 am
Try a magnet. If it sticks to the shells then it's standard power supply class.
If it is non magnetic you could strip them or take a #3 class at a local yard. Be it stainless or aluminium breakage
PostPosted: Sat Feb 06, 2016 3:36 am
boardsort has two classifications for power supplies... one for power supplies with wire and one for power supplies without wire... the ones you have pictured are the later. Currently, @ 10 cents/pound you would probably be better off breaking them down and they are definitely not worth the shipping cost to send in.
PostPosted: Sat Feb 06, 2016 2:09 pm
Sorry. True with/without wire difference. That's not where I was looking, was focussing on steel vs nonferromagnetic case. Thanks mls.
