It is currently Sun Aug 02, 2026 3:12 pm
Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: board grading.
PostPosted: Fri Feb 19, 2016 6:30 pm
Here's the bottle. I keep it in a glass jar because I don't use it often and it WILL eventually eat through the bottle.
PostPosted: Fri Feb 19, 2016 6:48 pm
You mean a formula for the acid test? i have plenty of hcl and used cu2cl (acid peroxide). No nitric though. Would the 20% rh you described be enough to protect the metal or would it react with the high amount of ni in the alloy. I guess that's more of a question for grf haha. But if you know all the better. I don't wanna post on grf until i at least finish hokes book.
PostPosted: Fri Feb 19, 2016 6:53 pm
Ok. So I see the bottle says nitric and Muriatic acid. So it's some form of Aqua regia?
PostPosted: Fri Feb 19, 2016 7:36 pm
yes. This has been my test base for some time.
PostPosted: Sat Feb 20, 2016 4:34 pm
The blend I've been using seems to be week enough to have little to no reaction most of the time. With 20/80
Best choice for doing your own blend is the grf. They are Far more experienced than I in that regard.
But my local guy scans anything large enough to hold so I generally stopped acid testing as long as they're willing to scan my little things. We find all sorts of strange alloys and give us all a laugh.
