| Site Admin |
Joined: Tue Feb 03, 2015 6:57 pm Posts: 10497 Location: Low DOS
Pin hubs. They go as gold pins but there is no set value. They need to be scanned on site to get the gold content vrs the base metal. They'll email you with a quote once they scanned them.
@18 pins my best guess is a 16 pin serial hub with two ground /fault pins. They come in different pin counts and sizes depending on application and most are rather old. My pure speculative guess is between 75c-$1.50 a pound. Based on early 90s pins with a brass base.
value (gold content) goes up with age as well as base material (nickel vs steel etc). So could easily be more or less.
