 Post subject: gold pins
PostPosted: Thu Mar 03, 2016 2:56 pm
what catagory would this gold pin filled board go under? the screws hold another 3 rows of pins
 Post subject: Re: gold pins
PostPosted: Thu Mar 03, 2016 4:05 pm
I have had similar go for back plane expansion... There are not enough pins to classify as pin-board.
PostPosted: Thu Mar 03, 2016 6:39 pm
Backplane with or without the plastic housing. There's not enough pins for pinboard.
PostPosted: Sat Mar 12, 2016 11:57 pm
What do pin boards pay. I have alot . Was gonna hold them. But I'm curious as to prices they range. And how many grades.
PostPosted: Sun Mar 13, 2016 12:08 am
You'd have to email Chris directly.
PostPosted: Sun Mar 13, 2016 12:39 am
if it helps give you an idea, i brought in some about 2 years ago and it was around $6/lb. I think it will also depend on if they are pins on both sides or not... the ones i had were single sided.
PostPosted: Sun Mar 13, 2016 1:19 am
There's a lot that goes into valuing pin/peg board. Including the plating, thickness, flashing. I've sent in both silver and gold pin/peg boards and received anywhere from $2-@8.something per lb in the last two years.
