It is currently Sat Nov 07, 2026 4:11 pm
 Post subject: Apple PowerMac mobo
PostPosted: Fri Mar 04, 2016 12:20 am
What would an Apple Powermac motherboard be graded at. It comes in two pieces but there isn't a removable CPU. Thanks in advance
 Post subject: Re: Apple PowerMac mobo
PostPosted: Fri Mar 04, 2016 12:50 am
Smll socket for embedded versions (soldered cpu) and large socket for many but not all Power (vic) macs with the large rectangle pga. You'd need to post a picture to be sure.
PostPosted: Fri Mar 04, 2016 7:04 am
Thanks. Here are pics of the front and back of each board. The smaller one was attached to the front of the bigger one. Thanks a lot for the help.
PostPosted: Fri Mar 04, 2016 10:47 am
One on the left is small socket or large socket. You'll need to measure the length.
One on the right is the cpu card. Green fibre with metal class.
PostPosted: Fri Mar 04, 2016 5:40 pm
So measure the length of socket on the bigger one and the smaller one would be green fiber CPU with metal? Just want to make sure. I really appreciate the help.
PostPosted: Fri Mar 04, 2016 6:09 pm
Yes. The large socket motherboard rate is based on greater than 7 inch periphery. so measure the sides and add them. That port, the tt-pga socket, comes in a few sizes most commonly 1.5x0.5 (4in) and 1.75x1 (5.5) and 2x1 (7)
PostPosted: Fri Mar 04, 2016 6:10 pm
Yes. Mac cpu cards go as green fibre with metal rate.
PostPosted: Fri Mar 04, 2016 7:39 pm
Thank you so much for your help. I got 7 of these units for $2 a piece and was trying to figure out my profit on them.
