PostPosted: Fri Mar 04, 2016 3:19 pm
Come off semi GPS dome
PostPosted: Fri Mar 04, 2016 6:02 pm
Looks like most will be gold plated pins. (Including the little bracket).
They need to be sent in and tested for an accurate quote based on gold content.
PostPosted: Thu Mar 10, 2016 12:37 pm
Thanks for the help!
PostPosted: Thu Mar 10, 2016 1:16 pm
That tiny little bracket, does it have a little ic on it with a glass window?
PostPosted: Thu Mar 10, 2016 6:43 pm
i have a glass coated ic with gold it..1inch long..gold legs...what catagory is that? thanks
PostPosted: Thu Mar 10, 2016 7:52 pm
I would think that with the green board under the chip, that the chip could go as green fiber with metal or green board without metal. If the chip could be desoldered without being damaged, it could fetch a higher CPU chip grade, probably a pentium ceramic.
PostPosted: Thu Mar 10, 2016 8:05 pm
i cant even get a razor blade between the ic and board
PostPosted: Thu Mar 10, 2016 10:25 pm
I usually desolder them and ship them as pentium, you may get green fibre with metal as is.
