It is currently Sat Nov 07, 2026 5:03 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2, 3  Next
PostPosted: Tue Mar 15, 2016 10:43 am
would this be a medium grade board...it has a lot of copper but also some little gold circles...shoud i remove copper or leave on?
PostPosted: Tue Mar 15, 2016 11:28 am
It's midgrade either way. You need a fairly good gold connector to make it to peripheral.
If you have a local yard you'll probably get a better rate for the copper removed from the board though.
PostPosted: Tue Mar 15, 2016 12:03 pm
ive been looking at that copper for two days now so i was hopin youd say that...thanks
PostPosted: Tue Mar 15, 2016 1:22 pm
Looks like a CCFL inverter from an LCD screen, I've got a pile of these I still need to pull the copper and chips off of, you'll make more with the copper transformers. Some are easy to take apart, others, not so much
The more I look at it the more it looks like the shell around the copper is iron hematite. When you remove them tap a corner of one with a tack or ball hammer. See if it's brittle. Would 'shatter' into nice clean shards like granite does.
Hematite is worth almost as much as copper if It is and your yard takes it it's worth smashing those completely.
PostPosted: Tue Mar 15, 2016 4:59 pm
My yard said they were powdered iron compressed into a powder, but I've been saving it. Will see what mine says when I bring my next load in
PostPosted: Tue Mar 15, 2016 5:23 pm
RCM wrote:
My yard said they were powdered iron compressed into a powder...
i got that initially too. They need to scan it and getting a yard to scan a small amount that they have made up their mind on isn't easy. And I could be wrong anyway.
PostPosted: Tue Mar 15, 2016 6:42 pm
Yeah, the yard I took mine too didn't have a scanner at the time, and they were rude to me. I use a different yard now, much nicer, and will ask them, I'll post back when I find out what it really is!
PostPosted: Tue Mar 15, 2016 7:09 pm
here is the same style board but with 14 gold teeth....but a lot of copper also...any advice on this one...im glad there not all this hard....if periferal weighs more with copper..if medium it has big gold teeth
PostPosted: Tue Mar 15, 2016 7:27 pm
Still midgrade. Sorry.
