 Post subject: Peri? Mid green?
PostPosted: Thu Apr 07, 2016 4:05 pm
Got a bunch for free. Thanks for the help.
 Post subject: Re: Peri? Mid green?
PostPosted: Fri Apr 08, 2016 2:05 pm
Technically it's an i/oboard. It will go peripheral rate.
PostPosted: Fri Apr 08, 2016 5:08 pm
Thank you! Forgive me. I'm learning. Have a few more. Any pointers of what to look for to help my grading would also be much appreciated so I can stop bugging y'all. Specifically indicators for green vs peri. Thanks a million in advance.
PostPosted: Fri Apr 08, 2016 6:39 pm
1) peripheral leave the cpu in the socket
2) peripheral
3) automotive board
4)Peripheral if you can get the heatsinks off
5)automotive board
Auto boards are peripheral boards that have a sealant applied to them.
PostPosted: Mon Apr 11, 2016 12:03 pm
Your "Classifying boards" post on Friday was very helpful. Thank you. I have a few more. Front/back. Didn't want to toss the larger ones in finger and have them downgraded since they're heavy. Have quite a few so I wanted to make sure. Thanks!
PostPosted: Mon Apr 11, 2016 2:12 pm
The first pair the small board will go backplane if the pins in the sockets are gold. Otherwise peripheral.
The large one... I'm not sure. Could be telco but on the very lowest edge of that class. The board is too big for finger card so I lean to telco but if not peripheral
Second card f/b is ohkay for gold finger card.
Set of 4 top to bottom
Peripheral
Backplane
Peripheral
Peripheral (possible telco)
PostPosted: Tue Apr 12, 2016 3:17 pm
Tracking unit? Breakdown. I see more value than board. Thoughts?
PostPosted: Tue Apr 12, 2016 4:00 pm
How about a nice normal motherboard? Please. Lol
The large board should clear telco. The gps board is peripheral, if you pop the spreader Loose you may have a Better board, telc, air card or even cell class.
The sd card is gold finger as is. If a plastic shell on it you can remove the shell and get telco. The sim, there's ways you can make it better I'm not going to discuss because it's not really worth it to most people and it needs to be done exactly correct for any bump. They have a class. Not on the list for quotes so toss it in and notate it in your submission confirmation text box.
Or refine it yourself. Post it on ebay etc.
The remaining boards are peripheral.
PostPosted: Tue May 03, 2016 4:17 pm
Two on top are the same. Two on bottom are the same. Just showing front & back. Came from telephone but wasn't sure that it would clear telco.
PostPosted: Tue May 03, 2016 5:57 pm
Bottom one may clear telco.
Top one is peripheral
