PostPosted: Tue Apr 12, 2016 11:44 pm
I will flip them over at your request
I found another box
what are these little guys?
worth the trouble to separate? Would boardsort accept this?
PostPosted: Wed Apr 13, 2016 2:06 am
1) I'm not even sure where to start so hold tight for a while I'll get back to you on this.
2) all ICs most likely. I can only see the top layer. pull out/sort anything with a gold cap or gold pins. Any anything with a silver squarion top or bottom.
3) safe for peripheral
4) wow. Looks like my bench. Again hang tight i need to download the photo and label it.
Some of that boardsort takes and some they don't but you're far enough along here to keep it sorted. I'll post back later today
PostPosted: Wed Apr 13, 2016 11:53 am
The top photo are bga chips. The ones with black tops go for about $25-$30 per pound on ebay.
The second pic are mixed ic chips. They don't sell for nearly as much.
The bottom two pics are various separate components that Boardsort will most likely not buy (it's kind of hard to see the components in the bottom pic)....if you have any if chips in the batch, throw them in the box in the second pic.
PostPosted: Wed Apr 13, 2016 1:40 pm
Ohkay here's my breakdown.
First picture.
The large ones around the outside will go as pinless.
The green fibre ones with gold corners will go as green fibre with metal
If the Texas instruments and alpha dat cpus are ceramic you can put them in green fibre with metal. If plastic they'll go as pinless.
The broken ones and anything not covered above will go as peripheral
Second picture
Boardsort pays 2.50 right now for ic chips. Again remove any that have gold legs, gold caps, or silver rectangles
Third picture
Definitely peripheral class. I send those quite often.
Final picture
Lets do this alphabet style. Top left of tray as a. right of that is b etc.
A)ic chips bs
B)cu #1 or #2
C)silver plated brass or nickel copper bs
D)not sure
E)ic chips bs
F)mixed capacitors prob al#2
G)ic chips bs
H)cu#1 (silver slugs) and cu#2 (rest)
I)mixed.CMCs tant, and ICs bs
J)ICs bs
K)remove the yellow one. Ceramic resistors.
L)ICs bs
M)empty
N)cu#1
O)cu#1
P)mixed pins. If mostly silver colour then cu#1
If gold in there can vary.
Top left box mixed. Needs sorting
Top right cu#1
Small bowl is mixed
Large one under it looks like most ic chips Bs
Bags all look mixed.
PostPosted: Wed Apr 13, 2016 6:50 pm
First picture.
Second picture
Third picture
Final picture
A)ic chips bs
B)cu #1 or #2
D)not sure
E)ic chips bs
G)ic chips bs
J)ICs bs
L)ICs bs
M)empty
N)cu#1
O)cu#1
Top left box mixed. Nerds sorting
Top right cu#1
Small bowl is mixed
PostPosted: Wed Apr 13, 2016 7:59 pm
When you do a quote, make Sure you type after the insertion.
you can also just hit reply. Most times quoting isn't necessary.
PostPosted: Wed Apr 13, 2016 8:06 pm
Sorry still learning.
PostPosted: Thu Apr 14, 2016 11:33 am
No problem just hard to figure out what you're saying when all there is is a quote. :)
