It is currently Tue Jul 28, 2026 4:34 am
 Post subject: Acousto-Magnetic tags
PostPosted: Mon May 02, 2016 11:26 am
I was wondering if there was any value in acousto-magnetic article surveillance tags?
Thank you
PostPosted: Mon May 02, 2016 12:51 pm
Steel rate is my guess. I never opened one to see though
PostPosted: Mon May 02, 2016 2:16 pm
Thank you
PostPosted: Mon May 02, 2016 2:26 pm
Best guess, it must be electrically unstable to set off the dectors sensors so probably a 500 series chromium steel. .but I don't know how the systems work in the first place so that's just my best guess. Assuming your talking about the big plastic clamp on units.
If you are referring to the image posted below. The long rectangles are ferrite steel and worthless (steel rate) (black strip is ferrite iron, silver strip is chromium iron aluminium worth about a penny more oer pound)
The flat square ones sometimes have copper or nickel
In those cases the tags would go as the lowest grade of the metal, #3 or #4 at most large recyclers.
PostPosted: Mon May 02, 2016 6:56 pm
The DR series was the one I was stuck with. I suspected as much but with 10lbs of them I figured I would check. Thanks for the help
PostPosted: Mon May 02, 2016 7:15 pm
It's 25c more than you have without them?
Atleast there's that.
