It is currently Fri Aug 28, 2026 11:19 am
 Post subject: ID Please
PostPosted: Wed May 25, 2016 11:09 am
I've worked my way through most of the stuff I had yesterday, but I found a few things that were odd and need some help with!
The last three pics are ID pics, the first one is extra stuff that I don't see listed as something you'd take, so I need clarification on what to do with it besides make a hat! ;)
Thanks for all you guys do! :)
-Carrie
 Post subject: Re: ID Please
PostPosted: Wed May 25, 2016 12:49 pm
First pic
Two bios chips go in ic class.
The resistors on the left bs doesn't take but most recyclers will give you brass 3 or cbm 2
The jumpers on the right just plug them back into any open spots on the boards you took them off of. Better value as weight than gold pin connectors
Guy at the bottom if still had copper around it cbm 3 if not lt iron. Bs doesn't buy regardless.
Second pic
Midgrade
Peripheral
Peripheral
Peripheral
Third pic
Left.
Peripheral
Peripheral
Peripheral
Gold ram
Gold ram
Right
Peripheral (romove shield cover
Gold fingers (you can cut the green out for clean or take a minor deduction as is.
Final
possibly telco. Set it aside in your shipment
Peripheral
Peripheral or telco, depending on what's under the shield
Peripheral
PostPosted: Wed May 25, 2016 2:33 pm
One last question. The drive motor for the floppy drive (green with the round thing on it in pic 2). The green is not fiber board. It's on metal (steel maybe?), so does that change the grading?
Thanks for the assist.
-Carrie
[edit] Hubby has decided he wants to keep them for the magnets. (???) But I would still like to know if that changes the grading. [edit]
PostPosted: Wed May 25, 2016 2:40 pm
Not at all. Though you may get a better rate at a local yard for them as a motor.
PostPosted: Wed May 25, 2016 2:45 pm
The drive, you can pop the magnetic spin wheel (and the magnet) out to keep the magnet and sell the board. You loose a chance for motor rate though. Thus becoming cbm#3 and likely about the same as midgrade rate.
Also though this us a 3½ inch drive early 5¼ and 8 inch drive motors often hava a cobalt ring magnet. And good buy prices for that!
Changed poo to pop. Oops
