It is currently Sat Aug 29, 2026 1:17 pm
 Post subject: Ballast boards
PostPosted: Sat Jun 18, 2016 7:50 pm
Found some fluorescent light ballasts and took off the cover to find a heavy, crowded board in covered in a hard, tar-like coating.
I know I could scrap the ballast whole locally but I live in an area where the scrap yards are dishonest and ignorant so I try to stay away. (For example, I had a scrap yard worker hand back the blue copper I gave him because "there ain't no such thing as blue copper". I had him take a grinder to it and it blew his mind).
Anyways, what are we looking at here in the eyes of Boardsort? Lowgrade is my guess
 Post subject: Re: Ballast boards
PostPosted: Sun Jun 19, 2016 7:33 pm
Thr little guy is a resistor. Boardsort doesn't want them loose. Locally you'd get a cbm 1 or 2 rate. A good pair of shears or robogrips you can squeeze or cut the back from the shell from the back for a plate of silver brass or silver copper (boardsort buys that) some copper and plastic &steel or IF.
The boards are low grade and you're better off leaving the tar on and selling as a ballast.
The "wires" are insulated copper, not wire rate, To most places. or strip them for clean bare bright.
Finally look for a silver or grey color metal in one of those wires, some ballasts have a palladium grounding wire. Especially in neon/florescent commercial lamps. An alloy wire worth around $80/lb.
