It is currently Sat Nov 07, 2026 5:35 pm
PostPosted: Thu Jul 14, 2016 2:24 pm
Hello,
Do you accept Motherboards with the Ceramic Processor still on it? If yes, how much do you pay for those? I would like to have some type of idea before I ship them.
Thanks,
Joe
PostPosted: Fri Jul 15, 2016 9:07 pm
Depending on the processor it would likely be classed as large socket motherboard For basically anything newer than 586/pentium.
Or, as telco anything older than 486.
Though any gold cap CPUs would make the board high grade gold cap board.
May I ask why you'd leave them in? They're worth considerably more separated.
PostPosted: Sat Jul 16, 2016 12:51 pm
Thanks very much. I would rather not leave Ceramic Processor on the MB but I can't figure out how to get them off without pulverizing them. I've ruined 2 so far and decided to ask before I kept screwing them up.
Do you have instructions anywhere on how to remove them? I googled it but didn't find anything for "removing ceramic processors".
Much Appreciated,
Joe
PostPosted: Sat Jul 16, 2016 1:22 pm
If you're able to post a picture that would be the easiest way to tell you what you have and how to remove it. If you can. Some boards do have soldered CPUs. That said I'll update this in a few hours with a better detailed list of how to remove certain types of chips.
PostPosted: Sat Jul 16, 2016 5:08 pm
Great. And thank you. I will post a pic on Monday.
PostPosted: Sun Jul 17, 2016 2:00 pm
http://www.boardsort.com/escrapforum/viewtopic.php?f=5&t=2761for full response.
PostPosted: Tue Jul 19, 2016 1:13 pm
Hello,
Attached is a pic of the ceramic cpu.
Thanks,
Joe
PostPosted: Tue Jul 19, 2016 9:19 pm
dont remove it... i think you have a better chance of getting a higher grade with it on there. at best it would go as a no pin processor (since you said you cant pull them off) and your board will probably go as small socket server board. With it on, i think you are going to get a large socket server board (at worst) and telecom (at best).
PostPosted: Wed Jul 20, 2016 12:11 pm
That's a nice CPU as is.
Unfortunately it's a soldered SGA. Studs. And the design makes a heatgun removal a waste of energy. You'll spend more in electricity then you're going to recover.
I'd take a guess at large single sockets, or dual small socket.
And I'm leaning to dual small socket despite the single chip. Because:
I can't tell the numbers under the thermal paste but it looks like a dual CPU in a McCP. Two separate CPUs on a single die. All the other requirements are there for a multi CPU board.
You probably won't get telco for it. There's not enough IC population to push it over.
PostPosted: Wed Jul 20, 2016 3:38 pm
Thanks very much for the info Chris.
