It is currently Sun Aug 09, 2026 10:48 am
 Post subject: A few little boards
PostPosted: Tue Apr 29, 2014 12:52 pm
Alright so i tried to do pairs of the boards so its easy to see... I think the 2 in the lower left are laptop boards looks like a big processor was there.... The top left not sure has gold pins... Ones top right are from CD drive some are green both sides some are green one and white other then other is green one side yellow other... Just trying to find out
 Post subject: Re: A few little boards
PostPosted: Tue Apr 29, 2014 3:20 pm
The two larger boards are laptop motherboards. Laptop boards are large socket grade regardless of the actual CPU size. The small board with the exposed pins on the left side is peripheral. Middle small board is mid grade. The far right boards are low grade, the ones from the back of the CD drives.
PostPosted: Tue Apr 29, 2014 7:39 pm
Thank you man so what about the little motors on the low grade. If i cant get off without busting the board? Also what about solid floppy boards green one side brown other with the gold pins?
PostPosted: Tue Apr 29, 2014 8:35 pm
You can leave the motors attached but they are probably worth more at your local scrap yard. Disk drive boards with pins attached are peripheral. I had questions about those too and found a post in the forum from Chris answering that exact question.
PostPosted: Tue Apr 29, 2014 8:54 pm
Gotcha Gotcha he has in the price list CD ROM boards so thats what i went off for the main boards then you have your logic from hard drives. Im just trying to figure out what category for the floppy's
