It is currently Sat Nov 07, 2026 5:43 pm
PostPosted: Thu Aug 18, 2016 5:00 pm
Hi New Here, I'm trying to sort a bunch of stuff to send to Boardsort. I'm not sure where to put these boards ? I would be grateful for any help.
Thank For The Help
Pics #2 and 3 are the same item front and back
Pics #4 and 5 are the same item front and back
Genia
PostPosted: Fri Aug 19, 2016 3:06 am
Peripheral
Same
Green fibre with metal
Small socket
Same
PostPosted: Mon Aug 22, 2016 8:30 am
Thank You For the help with sorting this stuff.
PostPosted: Mon Aug 22, 2016 4:00 pm
The last board is mITX, style. These , commonly called Pie or pearl, boards for the is/I-o system used with them; for raspberry pie and pearl beach.
They are best sorted when each board is posted individually.
They fall into 3 categories and you can't be sure unless a sorter grades them individually.
ITX has been around since the early 80s with dozens of layouts and close to 100 different revisions like ATX motherboards while the screws fit a matching case, and it's I/o panel is supposed to be interchangeable; in the real world I've seen a few here and there that would just barely make it out of midgrade, and some boards that actually got regraded from telco to cell board. But also telco downgraded to peripheral.
