It is currently Sat Aug 29, 2026 11:58 am
PostPosted: Sat Sep 03, 2016 4:40 pm
I got a few old Sony CCD CCTV Security cameras. While they power up they aren't fit to sell as working. Each camera seems to have six different boards. I've labeled them Front #1(board with the CCD module - looks ceramic with gold legs), Motherboard #2 (has one physically attached daughter board plus the connections for three more daughter boards), Left Daughterboard #3, Centre #4, Right #5 and Rear #6. I've removed any metal shielding and the boards seem well populated. Note I stripped down the Front #1 board as far as I could without physically damaging the CCD module.
PostPosted: Sat Sep 03, 2016 5:27 pm
Bottom image is a mini CCD "DLP" chip. Depending on size it will go as peripheral board or green fibre DLP and I'm almost certain you're at peripheral there. It has to be oftly large to make green DLP, bigger than a quarter for the chip itself.
Don't try to remove it you'll ruin the pins and still get peripheral for the chip, and midgrade for the board.
The only ceramic DLP chips to go as such are the ones from TVs. Period.
I've sent hundreds over the past and was eventually asked to just put them where they belong and give up trying to game the classes. ;)
Rest is peripheral
Btw in general terms for scrap any windowed IC chip falls into DLP including EPROMs, CCDs, and DLP;, boardsort is quite specific as to what it will take as ceramic DLP, 50% of what is left, ceramic fibre or otherwise, falls into green fibre DLP and the remaining based on size as IC with solid straight pins and peripheral for the rest
PostPosted: Sun Sep 04, 2016 1:41 pm
Thank you
