It is currently Sat Nov 07, 2026 6:10 pm
 Post subject: Cell class??
PostPosted: Fri Sep 09, 2016 3:13 am
 Post subject: Re: Cell class??
PostPosted: Fri Sep 09, 2016 9:27 am
I dont deal with cell phone class that often, so keep that in mind.... I don't know if they will accept three on the left hand side of the top picture as cell phone class. The rest should definitely be good though.
I 'think' the three oddball ones will go lower because there is not much on there except flash plating... I would say they will probably go as peripheral, but they may have a separate way of dealing with cell phone boards like that.
I only send in a couple cell phones a year, and most of the time I leave them whole, so i could be off.
PostPosted: Fri Sep 09, 2016 1:21 pm
The real thin ones from the screens, the square hole, go in telco if populated and peripheral if not. I send that stuff in dozens of lbs at a time.
Again striped boards like your other post need to be confirmed. The main boards will probably still get peripheral but anything thinner like screen boards will be low or midgrade
PostPosted: Sat Sep 10, 2016 5:36 pm
Ok I am confused about what cell class is,
I thought cell phone is cell class....
What am I missing please clarify????
PostPosted: Sat Sep 10, 2016 10:55 pm
I do believe cell class boards are gold sandwich, meaning, gold in between the layers of the board.
PostPosted: Sat Sep 10, 2016 11:59 pm
Thank you for your time but what boards will I usually find them in?
PostPosted: Sun Sep 11, 2016 2:57 am
The main board of cell phones, & large secondary boards. Almost everything non flexible from them.
PostPosted: Sun Sep 11, 2016 10:28 am
So too clarify,
top picture telco,(except the two with square holes)
Bottom picture cell class
PostPosted: Sun Sep 11, 2016 3:31 pm
Top pic left side telco. Right side cell phone
Bottom pic all cellphone
PostPosted: Sun Sep 11, 2016 3:37 pm
Best way I can break it down.
Hard boards that are populated go cellphone
Hard boards that are unpopulated go telco
Soft boards (flexible) that are populated go telco
Soft boards that are unpopulated go peripheral
Soft boards that are literally paper thin and are populated can go peripheral
Soft boards that are literally paper thin and unpopulated go as mixed wire. The ultra thin stuff is laminated copper sheet; without components it's recycled the same as all flat wire.
