It is currently Sat Nov 07, 2026 6:19 pm
 Post subject: few more..
PostPosted: Sat Sep 10, 2016 5:27 pm
 Post subject: Re: few more..
PostPosted: Sun Sep 11, 2016 8:31 am
I'm wanting to send some more pictures for identifying, but I wanted to wait until all previous posts had been answered....
PostPosted: Sun Sep 11, 2016 6:39 pm
Peripheral
Peripheral cage needs to come off
Peripheral remove bracket
Top to b peripheral peripheral telco
Telco
Finger card; rest midgrade as is. Remove the Al and they're low grade.
PostPosted: Sun Sep 11, 2016 7:24 pm
First question, about picture #2, it also has a large bracket on the back, and a small sister board. And the black aluminum heat sink
Question 2) ,about 1st, 2nd,& 3rd picture, what about the wire,ribbon and copper?
Question 3) about last picture. Under the black plastic coating I was watching utube and he said it was gold "strands " true or false?
PostPosted: Sun Sep 11, 2016 8:26 pm
Yes the entirety of the cage needs to come off that one. Both parts of the steel
It's preferred that senders remove or clip all wires.
Both true and false. Those are very low grade bump ICs they do nothing for value of the board. There's gold, the bonding and transmission wires etc; but nothing close to even standard bump ICs like on remote controls or antennas.
If you're self refining there's gold to recover but there's so little you're wasting money doing so. Acids and bases cost more than the gold.
If you're refining 50lbs of cell phone boards and processors go ahead and toss them in your acid drum, minus the aluminium. But anything less than that much or more, ... Alone it's a waste of resources.
PostPosted: Sun Sep 11, 2016 9:57 pm
What about the copper on 1 & 2 and the heat sink on 2
PostPosted: Sun Sep 11, 2016 10:59 pm
In this case leave the transformers alone.
I don't see the heatsync your referring to.
PostPosted: Mon Sep 12, 2016 7:17 am
PostPosted: Mon Sep 12, 2016 1:51 pm
Lol. It's so perfect a rectangle I didn't look twice and thought it a relay box. :0
It's under 1/4 the board size so I'd leave it alone.
PostPosted: Mon Sep 12, 2016 8:35 pm
