It is currently Fri Aug 28, 2026 10:33 pm
PostPosted: Wed Sep 14, 2016 1:08 am
Hey all... Figured it would be easier to break this up into a couple of posts. Again, thanks very much!
PostPosted: Wed Sep 14, 2016 1:36 am
Again... Tomorrow
PostPosted: Wed Sep 14, 2016 2:46 am
Set 7) SIM cards don't have a category on the quote system but are accepted.
You can send them in; just make note of it in the text box on the final page of the quote.
Memory cards that are without case can go telco. With case goes peripheral or remove the plastic case for telco.
Set 6) plated copper. Goes in peripheral
Set 5) early equivalent of solid state drives. The go telco in most cases.
Set 4) 8086/8088
Set 3) gold pin board. Send it in to get scanned for a quote. Again not on the list so make note in the text box on the final page
Set 2) large socket
Set 1) telco
PostPosted: Wed Sep 14, 2016 3:40 pm
Lost,
On set 3: why would that not be considered a back plane? Is it because of the silver pins?
On set 2: I may say this wrong.....I realize that's a slotted mb, but with the amount of ic's what keeps it from going telco?
PostPosted: Wed Sep 14, 2016 3:46 pm
you might get gold cap chips board for that 'set 2' mother board... you have a single gold cap chip soldered to it, so i believe if you ask them you will clear it. otherwise, yes it would be large socket motherboard... thats just what they classify the old x286/x386 socket boards.
PostPosted: Wed Sep 14, 2016 5:31 pm
On two ; I was hesitant to say gold cap board but I'll defer to MLS for experience, I've never had a single cap CPU board to send in.
There's a weight vs materials offset on pre 386 boards. It's just how they classify them. Some do make telco but this one
Actually with the single gold cap you may get telco for this one, which is more likely in my guess than gold cap, but again until it gets there we're all guessing. ;)
Pin board is worth more than backplane. That server port is large enough to class it separately on such a small adapter board.
PostPosted: Wed Sep 14, 2016 9:29 pm
Well I kinda understand about the mb.
Im a little confused about the pin board......what makes it a pin board?
I went back an looked at the pictures again and realized the front of that board is nearly all pins. Is it because the amount of pins covering covering the board?
PostPosted: Thu Sep 15, 2016 2:03 am
You've got it exactly. One side is almost entirely pins.
PostPosted: Thu Sep 15, 2016 5:43 pm
Thanks Lost.....I appreciate all your help.
