PostPosted: Sat Sep 17, 2016 6:33 pm
File comment: I'm lost on these boards.
PostPosted: Sat Sep 17, 2016 7:14 pm
The 'glass centers' chips are called EPROMS (erasable programmable read-only memory) ... this post was edited to remove my stupid guessing! LOL Thanks for the corrections gentlemen!
Last edited by gentleman5926 on Sat Sep 17, 2016 10:58 pm, edited 1 time in total.
PostPosted: Sat Sep 17, 2016 7:25 pm
On the first 2, removing the EPROMS may downgrade them but not entirely sure, the other 2 probably won't hurt. They are just regular IC chips unless they have gold legs, then they can probably be considered Pentium ceramic.
PostPosted: Sat Sep 17, 2016 8:31 pm
EPROMs go as mixed ic's, I believe if they have gold legs they are of higher value.
Leave the ic's.......those are peripheral. Remove the ic's it may down grade them to mid grade.
Only remove ic's from low and mid grade boards. Peripheral or higher leave them.
PostPosted: Sun Sep 18, 2016 12:58 am
Ok I won't take anything off
But there are only 3 boards and each board has only proms, am I over looking one?
PostPosted: Sun Sep 18, 2016 1:11 am
Leave them in for peripheral rate. Take them out for midgrade.
Nickel, tin and silver legs are IC rate. Gold legs go as AMD ceramic most of the time and occasionally Pentium but very rarely anything higher
PostPosted: Sun Sep 18, 2016 1:48 pm
File comment: Is this a motor, or does it just work the actual Stepper motor
PostPosted: Sun Sep 18, 2016 1:55 pm
If I'm correct on what you're referring too, they're motors with a board or ICs attached as part of the assembly.
They usually have a board on the back, like printers, or a steel plate pcb, like cd/DVD drive motors.
PostPosted: Sun Sep 18, 2016 2:05 pm
File comment: This is what I'm referring to
PostPosted: Mon Sep 19, 2016 4:16 pm
You see, NOW I have to go out and try to find one to tear it apart.. thanks for that other project now Lisa!!! LOL Got my curiosity up about it's innards!
