It is currently Fri Aug 28, 2026 9:45 pm
PostPosted: Wed Sep 28, 2016 6:12 pm
Been away for a while, but I'm back. Got a box of these in today, maybe 15 or 20 lbs. I think E-prom or something, didn't see a price for them or a pic, maybe I've been away to long. Any help would be great. Thank's.
PostPosted: Wed Sep 28, 2016 7:20 pm
EPROMS they will go as regular IC chips, if they have gold legs then pentium ceramic I believe.
PostPosted: Wed Sep 28, 2016 7:45 pm
No gold leg's.
PostPosted: Wed Sep 28, 2016 8:32 pm
Regular IC chips then.
PostPosted: Wed Sep 28, 2016 9:37 pm
RCM,
Hey what about smaller ic's that have gold colored legs (not sure if the are brass or gold)?
I have some on some board that come out of mouse they are maybe 3/8" wide and 3/4"long. The board itself is a low grade (brown). I may need to take a picture of one.
Thanks
PostPosted: Wed Sep 28, 2016 10:07 pm
EPROMs with gold legs will go as standard ceramic CPUs. I put them in AMD ceramic
The laser diodes/led unit from mice go in IC with gold legs or peripheral with silver/nickel legs. Must have all the legs. Loose a leg loose the IC grade.
PostPosted: Wed Sep 28, 2016 10:09 pm
If you left the diode unit on the board the board gets peripheral (must remove scroll wheel).
PostPosted: Wed Sep 28, 2016 10:26 pm
O shoot I threw several handfuls in the the low grade..... Now I gotta go dig them out.
PostPosted: Thu Sep 29, 2016 12:28 am
Only the ones that you left the diodes on. But yes one with the gold legs get the board in peripheral.
PostPosted: Fri Sep 30, 2016 4:16 pm
I go through optical and laser mice like most people go through Halloween candy!
Technicians call the unit a ccd
Recyclers call anything with an optics hole a DLP.
The mice with gold pin optics will get peripheral for the same reason a disk controller makes peripheral.
The only time you should harvest the pins off the diode or even consider removing the diode at all is if it's a g series Logitech or a wired! Apple optical mouse. Where the legs are thick gold on nickel (from the same factory).
Otherwise the peripheral board rate works out better for you.
