It is currently Fri Aug 28, 2026 11:35 pm
 Post subject: Take the time?
PostPosted: Sun Oct 02, 2016 1:26 pm
 Post subject: Re: Take the time?
PostPosted: Sun Oct 02, 2016 2:56 pm
I do. ICs and gold I send to boardsort. Everything else winds up in various places.
PostPosted: Mon Oct 03, 2016 11:40 am
In full screen view of the first sorted.
the bottom right. High grade (#1) silver/nickel mix. I get nickel clean. $4.80/lb.
Bottom left silver L shred. Switches relays, tiny boards. #2 recovery. $4.00/lb
Top right Anything in a plastic or ceramic shell with 2-6 pins that is not an IC. I've cut the pins off and put them in the other bin. Nickel #2 $2.50/lb
Top left. Ceramic canister resistor. Cbm#1. $1.80/lb.
The final photo. Mixed fuses pre sort, driver bits, nickel/silver plated brass and copper heavy breakage, and the med bottle is organic resistors and capacitors.
