 Post subject: Gold pin connector??
PostPosted: Fri Oct 14, 2016 8:04 am
File comment: What needs to be removed?
What about the screws ...stainless steel??
 Post subject: Re: Gold pin connector??
PostPosted: Fri Oct 14, 2016 1:08 pm
Any wires need to be cut off.
PostPosted: Sat Oct 15, 2016 12:23 am
Thank you, what about the screws, sometimes stainless steel, aluminium, or metal. Leavr on or take off
PostPosted: Sat Oct 15, 2016 2:03 am
Excluding high end cables with flashy gold plated screws and brackets you can leave them.
Brass and nickel are worth more than the connector rate but you'll be loosing money in the time to get the screws out.
Most people can't tell difference between nickel and stainless.
Been doing this 20+ years in all and still make mistakes on occasion.
Best is just leave them as is.
