It is currently Fri Aug 28, 2026 10:34 pm
 Post subject: Telecom with gold?
PostPosted: Fri Sep 30, 2016 1:41 pm
I think this is Telecom, but I wasn't sure because of the gold chips. How do I grade this?
 Post subject: Re: Telecom with gold?
PostPosted: Fri Sep 30, 2016 4:05 pm
Perfect textbook example of gold cap chip board
PostPosted: Wed Oct 05, 2016 7:02 pm
better then telo high grade gold capped chip board @ $5.00 per lb currently
EDIT oops did not even see los's reply...
PostPosted: Sun Oct 16, 2016 10:03 pm
Does it still grade the same even with only one gold chip?
PostPosted: Mon Oct 17, 2016 1:22 am
Yes. In most cases; including yours.
Gorgeous Z80.
PostPosted: Tue Oct 18, 2016 8:22 pm
Thanks!
Are these all considered gold chip too? On two of them, some of the chips come out of sockets but there's still other soldered in place, should I remove the ones that are socketed?
On the last board pictured there's a Siemens device that's in gold? This board also has a 486 chip maybe?
PostPosted: Tue Oct 18, 2016 8:33 pm
Cyalume,
What are those boards out of? If you don't mind my asking......I have started buying from schools and counties and cities thru online auctions down here and I'm still learning what's good and what's not.
PostPosted: Tue Oct 18, 2016 10:24 pm
rdw1121 wrote:
Cyalume,
In the beginning of the thread old boards.
PostPosted: Tue Oct 18, 2016 11:09 pm
Thanks Cyalume.....those are some good looking boards
PostPosted: Wed Oct 19, 2016 2:42 am
Siemens boards that's a plated heatsink not a normal gold cap. That said it's still heavy plate so a gold cap board is probably still the correct classification.
The Moto 68000 series CPU is Motorola foreign gold cap
Any gold cap CPU you can remove is worth more as a CPU then the gold cap board rate will give you. Always remove gold cap CPUs that are socketed.
