 Post subject: Portable cd player
PostPosted: Thu Oct 27, 2016 11:56 pm
 Post subject: Re: Portable cd player
PostPosted: Fri Oct 28, 2016 12:41 am
Small one is midgrade big one peripheral, cut/pull the battery spring off.
PostPosted: Fri Oct 28, 2016 12:43 am
On the second picture, is that the dlp chip?
PostPosted: Fri Oct 28, 2016 12:44 am
The big wire is just that; wire
Small silver IC, you can cut that loose and put in peripheral
Rest probably better served in mixed wire as is but if you're local yard buys nickel you can cut the small pieces loose
PostPosted: Fri Oct 28, 2016 12:49 am
The small board has a silveride coupling. Under the plastic. It's worthless on its own. Get a few dozen lbs though and you've got silver recovery @ .50-.75
The small piece of wire has a silver IC that is a ccd that falls into the (non boardsort) DLP class of ICs. If you're local yard buys DLP chips that goes a metal DLP. Boardsort takes it as peripheral
Either way you're looking at $1-$1.30 per lb as of today.
PostPosted: Fri Oct 28, 2016 12:56 am
I confused myself just then, meant third picture .
Thought the green wire could be mix wire or something
PostPosted: Fri Oct 28, 2016 1:31 am
It is. You don't/have/ to do anything to it but pulling the DLP for peripheral is a wise choice. Rest of the wire I don't even bother with. Mixed wire and done.
