 Post subject: Telecom?
PostPosted: Wed Nov 02, 2016 8:37 pm
Found a server box thrown outside on the way home from work please tell me its a good find :-) thanks in advance
File comment: Can I remove and loose / detachable ICs with out hurting value
 Post subject: Re: Telecom?
PostPosted: Wed Nov 02, 2016 11:30 pm
In order
Telco
Peripheral
Telco
Peripheral
PostPosted: Thu Nov 03, 2016 12:09 am
In the third pic red board it ha dome ICs in sockets should i remove those or leave on ?
PostPosted: Thu Nov 03, 2016 1:45 am
Leave them in.
PostPosted: Thu Nov 03, 2016 12:00 pm
check that yellow cylinder on the red board... it is probably a battery. However, if it is a fuse leave it because it will be glass under the yellow sleeve.
PostPosted: Thu Nov 03, 2016 2:59 pm
Good catch MLS
That's a coupled line battery.
PostPosted: Fri Nov 04, 2016 1:00 am
Thanks will keep ICs on and remove that battery ...
