 Post subject: Telecom?
PostPosted: Mon Nov 07, 2016 5:48 pm
Would the connector test plugs be gold plated
 Post subject: Re: Telecom?
PostPosted: Mon Nov 07, 2016 6:37 pm
That's going to go as automotive board without box. There's a heavy epoxy on it.
Gold would be my first guess. Followed closely by a high nickel brass.
PostPosted: Thu Nov 10, 2016 2:59 pm
The jewelry store said they are gold plated does boardsort buy them
PostPosted: Thu Nov 10, 2016 3:02 pm
You can put them in with your gold plated connector ends.
PostPosted: Thu Nov 10, 2016 8:18 pm
Yes as is like that they're gold connectors.
If you cut them totally free of wire and epoxy including inside the tube you can send them in for a review and quote for gold pin rate, nuts too.
They will usually be somewhere between 70c and 90c per lb
