So I'm going to preface this with the fact that I don't ship anything that pays lower than CD boards due to shipping costs. So several of these items won't actually go to boardsort (unless something is worth pulling off a board), I just want to better understand what's here.
The CD drive, I had never seen before (or maybe once when I was really young). Thought I'd share the drive pics for fun but then also, is the board good for CD board category?
The small board next to the CD board I believe came out of the same drive, can it go GFC?
Top right was a floppy drive, can't remember which category I've seen the smaller ones that are brown and green on either side go, does this particular type get a better grade?
The motor on the other CD board, lower right, should be removed?
The other three lower left I would assume are good for HDD boards? I'm fairly certain two if not all three were on Tape Drives (I took them apart so long ago I can't remember now) and don't know if tape drives are too different to go in the same category.
Specifically wondering about the chips with the glass on these. I think I may have asked about something similar before but don't remember now. Obviously there's some visible gold and gold legs on some of the chips, are they all some kind of DLP chip?
The white ceramic component caught my curiousity. Is that component really a gas tube or is it just a label stating what it controls?
The chips on this board were really what I was interested in, hadn't seen the white ones before and the black one appears to have gold legs. Any thoughts on these? Back of the board is unpopulated.
I asked before about the board but not the ceramic chips. I had one fall off of a board, do they have value on their own, what category if so?
Walkie Talkies, looks like a lot of plating on them, for some reason I decided not to tear them down further after I got the housing off, any thoughts on these?
Printer scanners. Mostly I have the green ones but also a few ceramic. The small wires you can see running from the board to the (???) long shiny thing; is that a chip (???) are those gold wires?
The ICs on these (minus the lower right board) was what mainly caught my eye. Also the top right has a second smaller board attached to some pins and can be pulled off. Any thoughts on any of these?
