It is currently Wed Aug 05, 2026 10:06 am
 Post subject: Help with board grade
PostPosted: Sat Jul 17, 2021 7:00 am
Please grade my boards
PostPosted: Sat Jul 17, 2021 10:36 am
Large board - high peripheral
Small board - clean GFC
PostPosted: Sat Jul 17, 2021 12:13 pm
Can I do anything to improve to low telcom
PostPosted: Sat Jul 17, 2021 2:15 pm
No it doesn't have enough IC population to make high telco.
I think its barely low telco as it is.
Since they split peripheral and telco I am a little hesitant on the difference in high peripheral and low telco.
Before they split telco it was hard for me to grasp the lower end of telco. The higher end of telco was normally pretty easy, it would be a board slam full of IC chips.
PostPosted: Sat Jul 17, 2021 11:43 pm
Rdw is right this can't go high telco but I do believe this can go low telco. You've got a gold tab chip, a bunch of ICs without a lot of blank board and most of the connectors should have gold plated pins.
You should remove the last two aluminum heatsinks if you can without removing the ICs underneath.
PostPosted: Mon Jul 19, 2021 2:22 pm
Thank you both
