It is currently Wed Mar 18, 2026 3:55 am
PostPosted: Mon Jan 24, 2022 5:14 pm
Also does Boardsort purchase these?
PostPosted: Mon Jan 24, 2022 5:59 pm
Yes, those are purchased, most likely as either sun or pinless CPU's,
both of which are currently at $5.75 a pound. The connector pad would most likely go as gold pin connector. Some decent weight there. ;)
PostPosted: Tue Feb 01, 2022 2:42 pm
Does this need to be separated from the copper backing or can it be shipped complete? The only way to separate is with heat and i do not to ruin any of the gold content in chip for boardsort.
PostPosted: Tue Feb 01, 2022 2:46 pm
Some of these are as heavy as 6 POUNDS!
PostPosted: Tue Feb 01, 2022 3:04 pm
Also have these small ones
PostPosted: Tue Feb 01, 2022 6:16 pm
No, you don't have to remove the chip from the plate, it is the same price either way. The smaller ones are also the same, they are just that, smaller.
What is on the other side of the big copper coloured plate?
PostPosted: Wed Feb 02, 2022 10:06 am
PostPosted: Wed Feb 02, 2022 10:10 am
Ok, same as the rest.
PostPosted: Thu Feb 03, 2022 12:32 pm
I've never seen a CPU like this. What did it come out of? I guess the connector pad sits between the CPU and the board? Very interesting!
