It is currently Thu Oct 29, 2026 3:25 am
PostPosted: Fri Feb 03, 2023 5:10 pm
Would this be considered a P4/Green Fiber With Metal or a No Pin CPU?
Just want to be sure I understand how these would be graded.
Here is a closeup of each one.
Thank you for the help.
PostPosted: Fri Feb 03, 2023 11:13 pm
These are always considered no pin CPU's. Unless of coarse they are i series and can be tested for sale to boardsort as working CPU's.
PostPosted: Mon Feb 06, 2023 6:22 pm
Fantastic tip. Thank you for your help!
PostPosted: Tue Feb 07, 2023 12:01 am
Do you understand what a pin is?
Seems like an obvious thing but every now and then the way people ask things I wonder if they don't.
PostPosted: Fri Feb 10, 2023 5:49 pm
Yes I understand, but for those reading this thread, what is the best definition/description of a pin?
PostPosted: Fri Feb 10, 2023 11:32 pm
Test
Well that worked... let's try...
Pinless = LGA (Land Grid Array) No pins on the processor leaving it mostly flat; the pins are actually in the socket and the processor lays on top of them.
With pins = PGA (Pin Grid Array) There are multiple rows of pins on the processor that are inserted into a socket, just like plugging in a lamp into a wall socket.
