The packaging of the chips is a little different than normal, not sure what impact, if any, that will have. That being said, solder on the legs will usually lower the grade of any chip so removing is probably not the way to go. There is a large component mostly out of frame that appears to have a large piece of steel in it that will likely reduce the overall grade of the board as is.
I'm thinking high peripheral.
_________________ Here to learn more so I can recycle more My grades are my own opinion and not an official grade from Boardsort
