PostPosted: Thu Feb 05, 2026 5:24 pm
Hi, I am preparing a boardsort shipment and have 2 random pieces that I would like to clarify what they'd be considered as.
The larger board is the motherboard from a mid 1980s PC -high grade telecom?
The other board is an expansion card for a late 90s PC
Thanks
EDIT: Sorry for posting this in the wrong section. I see there is a dedicated section for identification!
PostPosted: Thu Feb 05, 2026 7:27 pm
Smaller looks backplane but I can't see any gold in the black sockets, if you can verify the pins have gold plating I would go backplane.
Larger definitely can go high telco. You can even pull the socketed ICs if you have a IC pile. DO PULL the Battery, brown plastic says Yuksa I think, near the ports.
PostPosted: Thu Feb 05, 2026 8:09 pm
Thanks for the reply. On that expansion board, the only gold pins I can see are in the white slots. All the other slots appear to have silver pins.
One more question if you don't mind - on that same 80s computer, I have this HDD controller card - would it just be a gold fingered card, or because of the age and amount of old school IC's would it classify different?
PostPosted: Fri Feb 06, 2026 11:29 am
So unless I'm missing something on that first smaller board, I'm thinking low peripheral.
The gfc should have enough ICs and pins there to get into high Telco.
