It is currently Wed Jul 29, 2026 4:11 pm
PostPosted: Sun Oct 12, 2025 4:51 pm
Hello all, wondering what these boards from the Kingston brand SSDs would go as. Assuming as regular SSDs but not certain since they have fingers not pins. And the slimmer drives as well since they also don't have pins, just gold fingers.
PostPosted: Wed Nov 19, 2025 3:24 pm
Ok. I will venture on an evaluation. The 2 bottom left are WIFI. 1 has the shielding on. The other. The shielding has been removed. The other 2 hard lower right. Seem to be SSD. I hear tell High Telecom can be accepted. That upper left board. I would submit. CD Rom.
PostPosted: Thu Nov 20, 2025 8:48 am
Sata connector will definitely be low grade hard drive board.
The rest, I'm having trouble finding similar posted at the moment (it's too early to search) but they should at the very least be low grade hard drive boards but good chance they can get classed better.
That sticker on the one, catwhisker pointed out as a shield, is just a sticker, you can pull it off if you want.
PostPosted: Thu Nov 20, 2025 3:33 pm
Sorry. I got to look really close at uploaded pictures. I immediately jumped at the conclusion they were Gold Finger WIFI. I can see that is only a sticker now. Good thing we have a lot of forum members with some seasoned escrap experience.
PostPosted: Sun Nov 23, 2025 5:25 pm
Direct pci SSDs I believe are high telco
PostPosted: Wed Dec 10, 2025 7:45 am
Thanks all. Catwhisker the lower left are two of the same type of board, one is just flipped over to show the backside. Same with the long skinny ones.
So if I understand correctly these all will either be low grade hard drive or high grade telco?
PostPosted: Thu Mar 26, 2026 11:51 am
The category change occurred after this conversation ¯\_(ツ)_/¯
PostPosted: Fri Mar 27, 2026 5:01 pm
Can't speak to that, just know the price list didn't have the update until sometime after February 2nd.
Speaking of...I should get another capture on the wayback machine for that :D
PostPosted: Thu Apr 02, 2026 11:44 am
austin86 wrote:
ohh I like the idea of putting the prices page up on the wayback machine.
Wow! Back in the "good" old days?
https://web.archive.org/web/20180315124 ... payout.php
PostPosted: Thu Apr 02, 2026 12:54 pm
I need to get mine out to the scrap yard here that still takes them before they completely close the door.
But yeah, wayback had been useful a few times for referring back to prices, so I try to remember to submit the payout page occasionally.
