 Post subject: Board id
PostPosted: Sun Nov 29, 2015 7:56 pm
Older boards
File comment: Back
File comment: Front
 Post subject: Re: Board id
PostPosted: Mon Nov 30, 2015 2:37 am
Top 6 peripheral more than likely
Bottom 3 are mid grade and low.
PostPosted: Mon Nov 30, 2015 3:50 am
What if some of the chip got stuck on the heatsink. What grade would the big board be. And can i throw that heatsink with my gold pins. I scratched it and it's a different color, so I'm guessing it's gold plated. And the little board I'm thinking peripheral. But not sure.
File comment: Front of smaller board.
File comment: Should I remove the metal from the bigger board that's attached to the connections
PostPosted: Mon Nov 30, 2015 2:17 pm
The little one is going to be mid grade.
The large one us now peripheral without the cpu :/
The gigabyte heatsync is gold plated. But it's very thin. Gigabyte and AsRock use the same heatsync with a different print on it.
Put it in it's own spot in a bag in your shipment though since the cpu is still attached.
Normally those two heatsyncs would be between 60-80 cents a pound. i usually toss them in my gold connector bag.
PostPosted: Mon Nov 30, 2015 5:05 pm
Thanks for all the help.I'm getting ready to send in my first load. So I'm just trying to get it right. Definitely takes a lot of learning in the e-scrap game
File comment: Back of the 2 bottom ones
File comment: Can I put with my gold finger cards? Not to sure about the 2 bottom ones.
PostPosted: Mon Nov 30, 2015 5:47 pm
Top pic mid on top peripheral below
Bottom pic. The riser card is backplane.
The wifi cards with the steel spreaders are peripheral. The ones without spreaders go telco. The gameboy card will be telco with one or two ics. You /may/ get ram if three ics.
The other cartridge card next to it is gold finger card.
