It is currently Sun May 24, 2026 9:43 pm
Post new topic Reply to topic  [ 14 posts ]  Go to page Previous  1, 2
 Post subject: Re: Bitcoin Mining Cards
PostPosted: Tue Apr 07, 2026 11:01 am
Both sets of pictures are actually pretty blurry, but meowpher's do have ICs still. The original pics don't seem to have any, but again the pictures are not great. Unless a better image is supplied I would stand by midgrade for the OP, meowpher's should be better than that though.
PostPosted: Tue Apr 07, 2026 1:30 pm
Meowpher the 10th wrote:
Sometimes the chip stays attached to the board, sometimes the top plastic layer is ripped off exposing the precious metal content, and often, the heatsink with the chip attached is ripped from the board, tearing the copper layer.
austin86 wrote:
it is if you are pulling the chips with the heat sinks... both you an OP posted photos of boards with the ICs pulled off, we can all see this
Sorry I missed the continuation of this.
I’ll say upfront here I know nothing of these type of cards. Just my first glance look. Appears Meowpher has some experience so I’ll differ to you before keeping or changing my grade.
Especially because I’m seeing the opposite of marked in close inspection of the poor images.
Looks like the original may have chips and the repost doesn’t.
So are these boards surface printed ICs with a shell, a sink on top? Such as you see with streaming boxes and retro game emulators?
If so (my eg go as high peripheral despite looking like midgrade junk) then this may actually qualify as high telco.
Even without the caps as long as the actual IC and printing is still there.
PostPosted: Tue Apr 07, 2026 1:36 pm
Let’s not lash out at each other over postings.
I’ve been in this game longer than some users have been alive. (I’m not that old though).
I’ve seen “low grade” looking brown boards go as telco and shiny “gold” boards get midgrade.
I’ve stripped and sold solid silver and gold wires. Found platinum and palladium connectors. Pulled 14k gold sockets from $10 calculators.
Nobody ever knows everything, that’s why we’re here.
If I’m wrong I’ll admit it. It’s good to be wrong because you learn something new.
PostPosted: Tue Apr 07, 2026 4:14 pm
I tried to edit my post mentioning Austin86, but seems it didn't edit. I apologize for my rude reply. I generally accept his grading and identification as accurate, but since crypto mining boards are not commonly discussed on this forum, I had questioned Chris and was merely reporting Chris words. At the time I did not know if the sinks would pop cleanly or if there would be damage to the population and substrate. Also, when I snapped the photos and posted this morning I did not realize the photos were so out of focus., and really did not show the features I was evaluating. Since I will be bringing in roughly a thousand pounds, in person drop off, of these cleaned hashboards, and about 200 pounds of peripheral high grade from the same batch, I really am not concerned about whether these go as mid grade or at a special quote. My main concern is removing the heat sinks to cut the volume by 2/3. Believe me, no one would intentionally try to remove 60 tiny heatsinks that would probably weigh less than two grams total.
