Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 17 posts ]  Go to page 1, 2  Next
 Post subject: What's inside it part 2
PostPosted: Thu Dec 03, 2015 12:27 pm
Dreamcast controller and vmu
The raw memory cards are peripheral as posted.
The actual visual vmu will be telco once you remove the tiny screen
The controller's board is peripheral
The cable end is gold connector
File comment: Gold cable end and class #1 insulated wire
File comment: Still more peripheral
File comment: Tiny peripheral class board
PostPosted: Thu Dec 03, 2015 12:46 pm
Leapfrog portable edutainment system.
Internally it is a Nintendo gameboy advance
The board is peripheral. You have the silver and rhodium mylar from the screen. An lcd screen. The led backlight ribbon. Some small wires steel and plastic
PostPosted: Thu Dec 03, 2015 1:01 pm
Code:
Edit]I just got an update from Chris today.
The little micro DLP units, both fibre and ceramic, go in the peripheral class boards, not respective DLP classes. [/edit]
By request: step by step disassembly of a CD/DVD laser head assembly
File comment: shortcut -- Cut here on both sides to slide out assembly easily
File comment: Size p-00
File comment: Steel left carbon right
File comment: L2r
Flat wire/ #1 wire / ceramic dlp
File comment: L2r
Silver heavy
Sealed motor /or/ cbm#2
File comment: Bracket mount will be aluminium or magnesium in most cases.
Lens unit with magnets... cbm #1 or copper #3
PostPosted: Wed Dec 09, 2015 4:28 pm
Tivo series 2
File comment: Shell off
File comment: Motherboard should make small socket. All pc ports +cpu n/s bridge chips
File comment: Quantum/maxtor Bigfoot has nice heavy board
File comment: Low grade power board
File comment: Front panel
File comment: Small peripheral board
PostPosted: Wed Dec 09, 2015 4:33 pm
Hifi VCR VHS deck
Lots of scrapyard stuff. Not much for boardsort.
Remove board. Yank out motor and heads. Cut screen off. Sell board whole.
File comment: Starting out
File comment: Nice peripheral controller.
File comment: As us midgrade board. Remove screen low grade board and platinum recovery screen
PostPosted: Fri Dec 11, 2015 4:26 am
AT&T Uverse wireless converter box
Pay attention to the screws. They're neither hex nor torx but "security star" size 6 inside size 7 outside
You're definitely not supposed to get in one.
Dont miss the silver signal sink. It's pure silver laminate.
File comment: Whole pain in the arse unit
File comment: Security star #7
File comment: Silver. Not much but every penny counts
File comment: Not much in wires
File comment: Gold finger card
File comment: Totally useless gold plated steel
File comment: Peripheral
PostPosted: Fri Dec 11, 2015 4:31 am
286 laptop
This unit has multiple variants in 286 and 386 varieties. Aside from the cpu they're identical. The 286 in this one went moto/foreign gold cap. It's not pictured
File comment: Laptop
File comment: Lid's up
File comment: Sweet. Aluminium nickel keyboard
File comment: It's open
File comment: Filleted like a fish
File comment: Oh my. WATCH OUT...
File comment: ...batteries on both sides
File comment: Rare case of power board making peripheral
File comment: Mobo will go telco
File comment: Pile of cbm (for scrap yard)
File comment: More peripheral
File comment: Mobo is telco
File comment: Hard drive board
PostPosted: Fri Dec 11, 2015 9:49 pm
Ibm wordpad cellular c3
Not much hear but it's better than nothing. Was a paperweight for a while. ;)
File comment: Unit...opened up
File comment: Screen.
File comment: Various wires
File comment: Copper. Cu laminate. And silver laminate (touch panel)
File comment: Gold pins and gold finger cut from screen
File comment: Cell class
PostPosted: Fri Jan 01, 2016 2:14 pm
Smart power strip with surge and brown suppression.
File comment: Unit
File comment: Inside
File comment: #1 yellow Brass (with silver)
File comment: #3 silver recovery
Or silver switches
File comment: Try ebay. Nice farm unit
File comment: #2 insulated copper (not wire)
File comment: Silver cable end
File comment: Heavy extension wire
File comment: Power board. Low grade for boardsort or transformer for steel yards.
File comment: Mixed small stuff
PostPosted: Fri Jan 01, 2016 3:20 pm
Cardscan 300 id/credit card scanner
Basically identical to the brother/lg lamination machine.. the heat bar replaced with a scanner bar.
Along with what's posted the bars are 308 stainless with brass mounts. Small sealed motor.
Bunch of plastic.
File comment: Top
File comment: Back side
File comment: Pulled open
File comment: Scan board with leds
File comment: Main board -> peripheral
File comment: peripheral
