It is currently Wed Jun 17, 2026 6:29 pm
 Post subject: What are these?
PostPosted: Thu Apr 30, 2026 2:38 pm
Need help identifying these
 Post subject: Re: What are these?
PostPosted: Thu Apr 30, 2026 3:24 pm
1 high perf
2 is a raspberry pi, if it works a lot of folks will buy it.
3 high perf
4 maybe low perf, you don't need to take the steel off the vga ends.
5 back plane if the pins are gold.
6 GFC
7 auto board without box.
PostPosted: Thu Apr 30, 2026 3:42 pm
Austin86. What category you putting board 2 in? I'm thinking High Peripheral. Everything else. I agree with your evaluations 100%.
PostPosted: Thu Apr 30, 2026 3:58 pm
the to play with pile lol. I always wanted a pie to play with but never got around to buying one. I'd say it's high peripheral
7 would be a simple upgrade if you can get all the glue/resin off and remove the steel on the left hand side. Some times that type of glue will peal right off, if not blast is with some caned air sprayed upside down or put it in the freezer and it might crack and peel off.
PostPosted: Thu Apr 30, 2026 5:02 pm
I actually thought about suggesting" peel off the sealant ". It did look like RTV to me. Which will peel easily and cleanly. I looked at the bare spot on the target chip. That is not a sign of a substance applied that will easily be removed.
But. WHY NOT? Whatever that is. Try to remove it. Get the upgrade.
Good suggestion Austin86. Lets see where this goes. Does it peel off. Do we get the upgrade?
Here to learn like everyboduy else.
My evaluations are my own.
PostPosted: Thu Apr 30, 2026 6:20 pm
sometimes heat can make it easier to peel off to but that gets risky if the glue is flammable
PostPosted: Thu Apr 30, 2026 7:12 pm
austin86 wrote:
1 high perf
3 high perf
6 GFC
I dont know if the Pie works or not it was left at my home with a bunch of other items that I cant ask the previous owner if they ever tested them, thats why im having to scrap alot of possible working items :(
PostPosted: Fri May 01, 2026 9:20 am
you could plug it in and find out. I think they use a USB cable for power
PostPosted: Mon May 25, 2026 9:29 pm
I ended up finding 3 raspberry pi and my daughter is now taken them and going to use them. Glad yall point it out to me I never noticed the symbol on the board. That was almost an expensive mistake.
PostPosted: Thu May 28, 2026 11:04 am
cool! what will she do with them
